Vivado 2015.1 not inferring RAM with attribute ram_style set
I am using one of the customer designs which has a memory model in it. I have specified the ram_style= block in the memory model, but still vivado does not infer it as ram and gives error:
Size of variable XYZ too large to handle.
The variable size is 512*8192 .
(* ram_style = "block" *) reg [WIDTH-1:0]           data [HEIGHT-1:0];
Any idea what else I can try to make Vivado infer it as RAM. Unfortunately I cannot share the customer design.
Rgds
Sapan
Tags (2)
Re: Vivado 2015.1 not inferring RAM with attribute ram_style set
Did you compare the coding structure with the given templates in Vivado? Refer below discussion:
http://forums.xilinx.com/t5/Synthesis/BRAM-instead-of-Distributed-RAM/m-p/641958#M15089
Anusheel
Helpful answer -> Give Kudos
Anusheel
hi
Are you using an asynchrnouis reset in your design?
Even if you define ram_style attribute, BRAM can be inferred only if you use synchrnous resets.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
@anusheel Do you mean even if I mention ram_style attribute, it has to follow the templates else it will not work?
The same RTl when run on some other SYnthesis tools work fine for me
Rgds
Sapan
Hello @sapan533,
Currently there is limitation of 1000000 on variable size in vivado.
Check the following thread:
http://forums.xilinx.com/t5/Synthesis/ERROR-Synth-8-4556-size-of-variable-is-too-large-to-handle/m-p/555791
--Syed
@sapan533
Yes, code should follow given guidelines to infer BRAM.
Anusheel
Hi @sapan533,
Can you try synthesizing block RAM for a smaller size?
This will let you know if the pre-requisites for BRAM are followed properly.
Tushar.
@tusharvi Trying with smaller sizes, synthesis is completed but it still doesnt infer it as ram.
INFO: [Synth 8-5546] ROM "data_reg[0]" won't be mapped to RAM because it is too sparse
Any idea?
Rgds
Sapan
Attribute is meant to guide the tools but it only affect the BRAM inference only the proper coding style is followed.
As pointed by Anusheel and Bharath Can you re-check the RTL?
Also is it possible to share your RAM template/code, so that we can check?
Yash
Hi All,
Thanks for all your help. I had to modify the ram model as per Vivado template and then it worked. Basically introduce an additional signal to read data. Earlier I was reading from same variable.
Now I have
reg [WIDTH-1:0] ram [HEIGHT-1:0];
reg [WIDTH-1:0] ram_data; // for the Vivado template
Rgds
Sapan
