Vivado - How to interface AXI
hi, i was generating a custom ip in vivado 2015.3 with several axi.
This generated the wrapper for my IP and 1 wrapper for each interface. The main wrapper instantiates the axi M00_AXIS, S01_AXI and AXI_INTR.
Based on the example i could instantiate my module in these axi wrapper, but i'd rather like to instantiate it in the top module of the custom IP, then connect the ports to all axi. Can I simply modify the port list of the axi wrapper for this or will it be overritten once i regenerate the interfaces?
thanks.
Tags (2)
Hi @mod24,
Please refer below
https://www.xilinx.com/support/documentation/application_notes/xapp1168-axi-ip-integrator.pdf
https://www.xilinx.com/support/documentation/ip_documentation/ug761_axi_reference_guide.pdf
Sarada
