naveenshankar
Vivado ILA Error!!!!
Hi all,
     Vivado ILA Is giving me lots of trouble, I generated bit and Ltx file in vivado 14.1 version and using same version hardware manager i fused code into FPGA. But i get this following error!!!
ERROR: [Labtools 27-147] vcse_server: Multiple trigger marks in window: 0, buffer index: 4.
ERROR: [Labtools 27-147] vcse_server: Could not get Parameter: trace_data.
ERROR: [Labtools 27-1829] vcse_server failed during internal command 'CseXsdb_getParameters'. See previous error messages.
Even i have taken care of STA : Timing violations.
 Can any body help me with this problem...
Thank you in advance
Naveen S
pulim
Can you reduce the JTAG clock frequency and see still yous ee teh same issue?
ashishd
Please check the related threads
http://forums.xilinx.com/t5/Design-Tools-Others/Vivado-2014-1-Debug/td-p/458536
http://forums.xilinx.com/t5/Design-Tools-Others/what-happed-to-my-debugging/td-p/325781
Ashish
vijayak
Hi @naveenshankar ,
I have seen few such cases where the design had timing violations and unconstrained paths.
Did you check that your design is fully constratined?
Thanks,Vijay
pulim
Naveen,
Just to add, the clock that is coming to debug hug is clean and free running.
If possible, please sahre the test case with me.
I will try to reproduce the issue at my end and will check if I could get any hint on the rootcause for the issue.
Manusha
naveenshankar
Hi Manusha,
             Ya Clk connected to ILA is clean and test cases you mean Exactly what??
Thank you
Naveen
naveenshankar
Hi Vijay,
    Yes my design is constrained and timing violations are taken care.. but still i am facing this problem
Thank you
Naveen
achutha
Can you check this in the latest version of Vivado 2014.4?
Achutha
naveenshankar
I keep getting this error, i dont understand the problem... can any body explain me the cause of this please??
ERROR: [Labtools 27-147] vcse_server: Arg. to function CseILA_unrollTraceMemory() failed:traceMemorySize >= (samplewordsizewithmark * sampleCnt * windowCnt)
Thank you
Naveen
vijayak
Hi Naveen,
Please check the unconstrained paths in your design. Run report timing summary..Refer to the screenshot.
Thanks,Vijay
achutha
Details of the Error:http://www.xilinx.com/support/answers/62421.html
Achutha
vijayak
Hi @naveenshankar ,
Did that helped? let us know if you have any queries.
Thanks,Vijay
