Accepted Solution
Vivado promgen equivalent
for configuring the Programmable Logic of a Zynq from its Processing system one needs a .bin file. In ISE this .bin file can be generated out of a .bit file with the promgen tool. Vivado does not have this tool.
In the bitstream settings on can specify that a .bin file should be generated, but this file differs from the one generated by promgen and cannot be used to configure the logic (at least not in the obvious way).
So the question is: How can one generate an appropriate .bin file with vivado?
With promgen I have used the following command:
promgen -b -w -p bin -data_width 32 -u 0 bitfile.bit -o bitfile.bin
Best  regards,
Yaro
Re: Vivado promgen equivalent
Hi Yaro,
You can check the following link for the procedure mentioned on page 15 of "Vivado Programming & Debugging Guide" to create the bin file for the proms/flash
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug908-vivado-programming-debugging.pdf
for BPI 16 width flash bin file generation is
write_cfgmem -format bin -interface bpix16 -size 128 -loadbit "up 0x0 c:/main.bit" -file main.bin
You can modify according to your requirement.
--Krishna
All Replies
http://forums.xilinx.com/t5/Design-Tools-Others/promgen-Command-Line-Help/td-p/322729
http://forums.xilinx.com/t5/Design-Tools-Others/Promgen-Migration-to-Vivado-Bit-byte-swapping/td-p/390017
ISE to Vivado migration guide help
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_2/ug911-vivado-migration.pdf
Thanks,Vijay
Hi Yaro,
--Krishna
Thank you!
