afmir7878
VmodCAM and Nexys3
I am working to operate the Vmodcam with Nexys3.it works but in the screen there appears a garbage display.
balkris
I provide links to various places that have different demos. I hope his will help you in your quest.
Nexys 3 - https://reference.digilentinc.com/nexys:nexys3:nexys3
Atlys - https://reference.digilentinc.com/atlys:atlys:atlys
VmodCam - https://www.digilentinc.com/Products/Detail.cfm?NavPath=2,648,931&Prod=VMOD-CAM
Thanks and Regards
Balkrishan
u4223374
Advisor
Advisor
And?
Making the assumption that it was meant to be displaying a picture, I can say that there's a problem either with the code or the hardware. Since you've provided no details of the code (eg. providing the code itself, explaining how you're trying to get the camera working, what pins you're using, what clocks you're using, etc) it's not possible to provide any more help.
florentw
Hi @afmir7878,
We cannot help you without more information...
What tool are you using?
Which IPs are you using? Can you share a screenshot of your BD if you have one?
Did you try some basic things before? As the Test Pattern Generator as video input?
etc...etc...
Florent
afmir7878
I am using the vmodcam and I make it work with this program. I use Nexys3 spratan6
