What OS does SD-SoC support?
Hello
I want to know the Linux-OS suppored by SD-SOC.
I knew below document;
https://japan.xilinx.com/support/documentation/sw_manuals_j/xilinx2018_2/ug1294-sdsoc-rnil.pdf
・Linux  support;
○ Red Hat Enterprise )Workstation 7.3-7.4 (64 -bit)
○ Red Hat Enterprise )Workstation 6.7  and 6.8
○ CentOS 7.2
○ Ubuntu Linux 16.04.3 LTS (64 bit)
- Linux  kernel 4.4.0
- Ubuntu LTS enablement (HWE  or  Hardware Enablement ) is not supported.
I want use latest Ubuntu(maybe Ubuntu 18).
Can I use Ubuntu 18 for SD-SOC?
syedz
kunihiko.kawahara@toshiba-visual.com
The OS which are mentioned in the release notes of SDSoc are only supported.
Ubuntu 18 has not been tested so it will be an unsupported OS. We would strongly suggest users to always use supported OS only.
--Syed
syedz
--Syed
watari
Professor
Professor
Hi kunihiko.kawahara@toshiba-visual.com
I suggest using ex. viertual box or docker on Ubuntu host, if you want to use Ubuntu OS.
This is only way to use SDSoC on Ubuntu OS.
Best regards,
Thank you for your advice.
I'll try it.
regard
Syedz-san.
Unfortunately, I'll try  Ubuntu16.
Regard
