sunayana.chskradhar
What is the main difference between Vivado and ISE?
I would like to the main difference between zynq 7000 devices which use vivado and the previous devices which used ISE. Also I have read in the internet that Vivado comes with SDK. What does SDK actually do?
How different is SDK from EDK. What are the major differences between ISE and Vivado? Does ISE include EDK or SDK?
What all packages does Vivado include and what all does ISE include. Please provide me with the differences.
avrumw
Expert
Expert
Okay with regard to virtex 5, 6, spartan devices, they too have hardened processors right?
Mostly no.
No members of the Virtex-6 or any Spartan devices (3 or 6) have hard processors. If you need a processor in these devices you have to use a soft core - generally the MicroBlaze. The MicroBlaze is implemented in the fabric of the FPGA - using the LUTs and other resources that are available to the desginer.
The Virtex-5 had the FXT sub-family of devices that had a hard PowerPC core. However, the interaction between the core and the rest of the FPGA was very different.
In the Zynq, the PS is a complete programmable subsystem - a CPU with all the peripherals that you would find on an embedded microcontroller. Furthermore, the PS is "in charge" - the PS must boot first, and only the PS can program the rest of the FPGA fabric.
In the Virtex-5FXT, the PowerPC is just a CPU (and caches). As opposed to the Zynq, the PowerPC is essentially a slave of the fabric - you must bring up the FPGA fabric before you can start booting the PowerPC.
SDK has been used for all Xilinx processor systems - hard and soft, and has been used for both tools - ISE and Vivado.
Avrum
arpansur
Hi @sunayana.chskradhar,
ISE comes with SDK. Please go through following link to get more information on what all things are included in ISE
http://www.xilinx.com/products/design-tools/ise-design-suite.html
http://www.xilinx.com/publications/matrix/Software_matrix.pdf
Please go through following link to get more information on what all features are included in EDK
http://www.xilinx.com/products/design-tools/platform.html
Please go through following link to get more information on SDK
http://www.xilinx.com/products/design-tools/embedded-software/sdk.html
Arpan
Arpan
sunayana.chskradhar
Okay with regard to virtex 5, 6, spartan devices, they too have hardened processors right? Then why only for zynq do we have separate PS and PL. what is the significance of this? What was the SDK equivalent for virtex and sparten devices?
arpansur
Please go through the following links:
http://www.xilinx.com/products/silicon-devices/soc/zynq-7000.html
http://www.xilinx.com/support/documentation/data_sheets/ds190-Zynq-7000-Overview.pdf (page-1 and 2)
Hope this addresses your concern regarding PS and PL in Zynq.
Arpan
Arpan
avrumw
Expert
Expert
Mostly no.
Avrum
nupurs
Please let us know if your query is addressed or you need more details on this topic from our side.
Nupur
Nupur
