deepak1991
Whether it is possible to program a FPGA(zynq fpga) using ARM PL JTAG,if possible then which cable i have to use and how to program?
Hello everyone,
             I am using Zynq ZC702 evaluation board.whether it is possible to program a bit file using ARM PL JTAG,If it is possible then please let me know how to do that.And which cable i have to use for programming the FPGA?
arpansur
Hi @deepak1991,
I didn't get your query correctly. Are you looking for a way to program only PL using JTAG?
Arpan
deepak1991
Hello Arpan,
     I am trying to download bit file into PL using ARM PJTAG Header(J41) in evaluation schematics.whether it is possible to download using this JTAG?
vijayak
Hi @deepak1991
Please avoid creating multiple threads for the same topic.
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Whether-it-is-possible-to-program-a-FPGA-zynq-fpga-using-ARM-PL/m-p/751853
Thanks,Vijay
