vibishna
XAPP1172: Error: initializer element is not constant
I was trying to run the xapp1172 for reading the values from XADC using a Makefile (running on the target):
CC=gcc
# Executable name
TARGET=xadc
# GCC compiling & linking flags
CFLAGS=-g -std=gnu99 -Wall
CFLAGS += -DVERSION=$(VERSION) -DREVISION=$(REVISION)
CFLAGS += -Ixadc_lib/include
CFLAGS += -Ixadc_lib/src
CFLAGS += -Ixadc_lib/linux_include
#CFLAGS += -I../../tmp/linux-xlnx-xilinx-v2015.2.01/include
LIBS=-lm -lpthread
# List of compiled object files (not yet linked to executable)
OBJS = xadc_lib/src/xadc_core.c xadc_read_cmd/src/xadc_main.c
# List of raw source files (all object files, renamed from .o to .c)
SRCS = $(subst .o,.c, $(OBJS)))
$(TARGET): $(OBJS)
$(CC) -o $@ $^ $(CFLAGS) #$(LIBS)
But I am getting the following error:
xadc_lib/src/xadc_core.c:121:111: error: initializer element is not constant
xadc_lib/src/xadc_core.c:121:111: error: (near initialization for 'gXadcAlarm[0].callback')
make: *** [xadc] Error 1
I checked the 121th line of xadc_core.c:
struct XadcThreshold gXadcAlarm[EAlarmMAX] = {
[EAlarmVccInt_TH] = { EAlarmVccInt_TH, "in_voltage0_vccint_thresh", 0, 0, conv_voltage, false,(struct Xadc_callback){0,0}, NULL},
[EAlarmVccAux_TH] = { EAlarmVccAux_TH, "in_voltage4_vccpaux_thresh", 0, 0, conv_voltage, false,(struct Xadc_callback){0,0}, NULL}, // todo: workaround
[EAlarmVccBRam_TH]= { EAlarmVccBRam_TH, "in_voltage2_vccbram_thresh", 0, 0, conv_voltage, false,(struct Xadc_callback){0,0}, NULL},
[EAlarmTemp_TH] = { EAlarmTemp_TH, "in_temp0_thresh", 0, 0, conv_temperature, false,(struct Xadc_callback){0,0}, NULL}
I have no clue! Any help in this regard will be great!
vibishna
I modified the code and it is working!
vibishna
