taylo019
XUPV5-LX100T evaluation platform CF card initial contents
I have recently received a Xilinx XUPV5-LX100T evaluation platform and am working to get it up and running. I have read the user manual and related documentation and cannot get past this problem.
It seems that when the system boots, I do not have the options to select the initial tutorials and/or my own ACE file. When looking at the contents of the CF card, it doesn't look the same as the user manual seems to expect with a new system. This is likely the result of a previous user modifying the CF card contents.
Is there a way to find the original contents of this CF card? Thank you for your time and patience with a new user.
austin
"flash images"
http://www.xilinx.com/products/boards/xupv5/reference-designs_prev.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
t,
Have you checked
http://www.xilinx.com/univ/xupv5-lx110t.htm
Austin Lesea
Principal Engineer
Xilinx San Jose
taylo019
I've tried looking here, but unless I'm overlooking it, I can't find the original state of the CF card that the system came with.
I did use this site to find the user manual and some reference designs that have helped.
austin
"flash images"
Austin Lesea
Principal Engineer
Xilinx San Jose
taylo019
Thank you!
