Xilinx system generator
I am working in xilinx system generator 14.2 with matlab 2014a.im getting this error while compiling using system generator.
The name 'UserData' is not an accessible property for an instance of class 'com.xilinx.sysgen.guitools.xlHwcosimCompileWaitBox'.
please help to proceed .
Do you mean ISE14.2 and MATLAB 2014a?
These are not compatible tools
You can find the compatible tools from the below AR
http://www.xilinx.com/support/answers/17966.html
Satish
