Xilinx xapp1052 xbmd.ko cant' load
Hey
I am doing the xapp1052, I use a host computer linux and the version of the kernel is 2.6.32-358.11.1.el6.x86_64 after the compilation I want load the file xbmd.ko unfortunately it'snt work. Is it problem with my version of kernel ? I search a solution about my problem but I don't find. If you have experience about this problem you can share your experience.
In the terminal I have this message.
[root@tibacou xbmd]# insmod xbmd.ko
insmod: error inserting 'xbmd.ko': -1 Operation not permitted
My board sp605 is detected by the host computer
[root@tibacou xbmd]# lspci
03:00.0 Memory controller: Xilinx Corporation Device 0505
Best REgards.
Re: Xilinx xapp1052 xbmd.ko cant' load
I add more information about my problem I have problem with the function request_irq my kernel disp this messages and I don't know how resolve this problem.
xbmd: Init: Base hw val E0600000
xbmd: Init: Base hw len 65536
xbmd: Init: Virt HW address C60000
xbmd: Init: Device IRQ: 0
xbmd: Init: Initialize Hardware Done..
xbmd: ISR Setup..
IRQ handler type mismatch for IRQ 0
current handler: timer
Pid: 5694, comm: insmod Not tainted 2.6.32-358.11.1.el6.x86_64 #1
Call Trace:
[<ffffffff810e2762>] ? __setup_irq+0x382/0x3c0
[<ffffffffa0018110>] ? XPCIe_IRQHandler+0x0/0x80 [xbmd]
[<ffffffff810e2e73>] ? request_threaded_irq+0x133/0x230
[<ffffffffa00187e0>] ? XPCIe_init+0x0/0x350 [xbmd]
[<ffffffffa00189bd>] ? XPCIe_init+0x1dd/0x350 [xbmd]
[<ffffffff8100204c>] ? do_one_initcall+0x3c/0x1d0
[<ffffffff810b74c1>] ? sys_init_module+0xe1/0x250
[<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b
xbmd: Interrupt Handler Start ..
xbmd : REG<0> : 0xFFFFFFFF
xbmd : REG<1> : 0xFFFFFFFF
xbmd : REG<2> : 0xFFFFFFFF
xbmd : REG<3> : 0xFFFFFFFF
xbmd : REG<4> : 0xFFFFFFFF
xbmd : REG<5> : 0xFFFFFFFF
xbmd : REG<6> : 0xFFFFFFFF
xbmd : REG<7> : 0xFFFFFFFF
xbmd : REG<8> : 0xFFFFFFFF
xbmd : REG<9> : 0xFFFFFFFF
xbmd : REG<10> : 0xFFFFFFFF
xbmd : REG<11> : 0xFFFFFFFF
xbmd : REG<12> : 0xFFFFFFFF
xbmd : REG<13> : 0xFFFFFFFF
xbmd : REG<14> : 0xFFFFFFFF
xbmd : REG<15> : 0xFFFFFFFF
xbmd : REG<16> : 0xFFFFFFFF
xbmd : REG<17> : 0xFFFFFFFF
xbmd : REG<18> : 0xFFFFFFFF
xbmd : REG<19> : 0xFFFFFFFF
xbmd : REG<20> : 0xFFFFFFFF
xbmd : REG<21> : 0xFFFFFFFF
xbmd : REG<22> : 0xFFFFFFFF
xbmd : REG<23> : 0xFFFFFFFF
xbmd : REG<24> : 0xFFFFFFFF
xbmd : REG<25> : 0xFFFFFFFF
xbmd : REG<26> : 0xFFFFFFFF
xbmd : REG<27> : 0xFFFFFFFF
xbmd : REG<28> : 0xFFFFFFFF
xbmd : REG<29> : 0xFFFFFFFF
xbmd : REG<30> : 0xFFFFFFFF
xbmd : REG<31> : 0xFFFFFFFF
xbmd Interrupt Handler End ..
xbmd: Init: Unable to allocate IRQ
This recall me a problem I had.
I'm pretty sure that there is an old thread that give some solutions about that.
In my memory it was an issue regarding your Kernel version and/or about MSI interuption
Some old piece of code :
 //enabling msi if possible
    if ( 0 != pci_enable_msi (dev) )
        printk(KERN_INFO"%s: Warning : MSI are not supported by mother board\n", gDrvrName);
    else
        dp->driverStatus = dp->driverStatus | HAVE_MSI;
        printk(KERN_INFO"%s: MSI are supported by mother board\n", gDrvrName);
#if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,21)
    err=request_irq(dev->irq,my_isr, IRQF_SHARED,my_sname,dp);
#else
    err=request_irq(dev->irq,my_isr, SA_SHIRQ,my_sname,dp);
#endif
What is your kernel version, I stopped to use my driver at version 2.6.28
I use the version Linux tibacou 2.6.32-358.11.1.el6.x86_64 I search on the forum but I did'nt found a solution about my problem.
In the code source if (0 > request_irq(gDev->irq, &XPCIe_IRQHandler, IRQF_SHARED | IRQF_SAMPLE_RANDOM, gDrvrName, gDev)) { printk(KERN_WARNING"%s: Init: Unable to allocate IRQ",gDrvrName); return (CRIT_ERR); } The function request_irq return a value != 0 there is problem with code source of Xilinx.
Yes it must return something >0
You should try the function : enable_msi as I said
Or maybe add :
pci_set_master(dev);
 just before requesting the irq
