rahul_espl
Xilnx IOT kit
Dear Team,
Do we have IOT kit which is developed by Xilinx?.
Rahul Soni
balkris
You require to contact your local FAEs.
check resources here
https://www.xilinx.com/applications/megatrends/industrial-iot.html
Thanks and Regards
Balkrishan
balkris
Thanks and Regards
Balkrishan
