ZYNQ PS<->PL DMA transfers
I have designed a simple PL with 32 registers on AXI lite and want to use the integrated DMA to do data transfer between the PL and the PS. Is there any documentation or tutorial about this scenario? Can someone tell me the necessary steps? It's not obvious from the provided documentation that I found so far.
Many thanks in advance!
For the most details, you will want to check the TRM but also ARM's documentation on the PL330 DMAC
www.xilinx.com
