Accepted Solution
Zynq 7010 (ZYBO) ucf file
Hello!
I'm working on a PR project with ZYBO. I use Xilinx ISE 14.6 and i have some difficulties to generate my ucf file and if i try to access to "I/O planning (PlanAhead) - Post Synthesis" I have this message :
" Unable to get a license. There may be a problem with your FLEXNet configuration, or your license server may be down. What would you like to do ---> Retry; Get license... and Exit".
I don't really understand because I have a valid license.
In the UCF file, I have a top module which contains clk (10 ns) reset (valid on high) and output(4 bits). I would like to connect my clk and my reset to the system clock and system reset. And connect the output data to the Leds (M14; M15; G14; D18).
Mohamed.
Re: Zynq 7010 (ZYBO) ucf file
If you could, please move to Vivado for Zynq. My guess is you need not any special license for Zybo, you would need to activate webpack.
-Pratham
All Replies
-Pratham
