Visitor almaz1988_2
Zynq ADC pin selection
Hello!
I need to design zynq-7000 based board to get some functionality including 12 ADC channels.
First of all I read this:
http://zedboard.org/content/zynq-pins-deep-dive
There is explained that I need:
1) determine used chip - xc7z020clg400
2) open corresponding pinout file:
http://www.xilinx.com/support/packagefiles/zynq7000-pkgs.htm
3) select pins which has AD#P/N in their names.
If I don't need differential mode do I need only one pin (P or N) from
every XADC pins pair?
For example:
C20  IO_L1P_T0_AD0P_35
B19 IO_L2P_T0_AD8P_35
E17 IO_L3P_T0_DQS_AD1P_35
E18 IO_L5P_T0_AD9P_35
M19 IO_L7P_T1_AD2P_35
M17 IO_L8P_T1_AD10P_35
L19 IO_L9P_T1_DQS_AD3P_35
K19 IO_L10P_T1_AD11P_35
J18 IO_L14P_T2_AD4P_SRCC_35
F19 IO_L15P_T2_DQS_AD12P_35
J20 IO_L17P_T2_AD5P_35
G19 IO_L18P_T2_AD13P_35
Re: Zynq ADC pin selection
Users can optionally configure the external analog input channels to operate in unipolar or bipolar modes.
Refer to Analog Input section in page 28 of http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf.
Praveen
