Visitor stefuni
Zynq: UART use modem control RTS/CTS only
I'm new to Zynq (did some spartan-3 in the past) and have a problem that must have occured before but I can't find anything on the subject.
I managed to get the UART0 signals on the EMIO interface and connect RXD and TXD to IO pins. Now I want to add RTS/CTS and have added "modem" lines to EMIO. But this includes all modem lines, not just RTS/CTS. If I just assign RTS/CTS to pins and leave the others default I get errors during bitstream generation:
ERROR: [Drc 23-20] Rule violation (NSTD-1) Unspecified I/O Standard - 4 out of 138 logical ports ...
ERROR: [Drc 23-20] Rule violation (UCIO-1) Unconstrained Logical Port - 4 out of 138 logical ports ...
How to only connect specified modem lines to EMIO and IO pins?
I'm using a MicroZed board and Vivado 2014.2
Stef
Visitor stefuni
Re: Zynq: UART use modem control RTS/CTS only
Okay, I have found a solution in the mean time:
-Expand the UART0 bus
- Connect the signals you want
- Tie up any left over inputs to a constant
See attached picture as well.
As you know that you are only using  RTS/CTS of modem, you can reduce this error to warning using following commands
set_property SEVERITY {Warning} [get_drc_checks NSTD-1]
set_property SEVERITY {Warning} [get_drc_checks UCIO-1]
this usually is not recommanded but in your case this will not cause any issue
hope this helps
thanks
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
This is not correct.  When the IO are not explicitly assigned both a location and IOSTANDARD it can create problems at the board level which is why this DRC exists.
Every I/O needs to be properly constrained to ensure a functioning design.
Visitor stefuni
Ok, so just ignoring the error is not a good option. Other problem with that solution is that it turns all errors of that kind into a warning, not just the ones about the intended signals.
But is there another solution to use only part of the modem lines of a uart? Can I for instances get them out of the 'bus' from the PS block and tie them up in the PL? How would I do this?
Same issue comes up with the SPI. If routed to the EMIO, it includes three SS signals where I need only one to go to a pin.
Visitor stefuni
