kpench
Zynq XC7Z020 - DDR3 design with ECC supp
We are planning to use the DDR3 inbuilt controller of XC7Z020 PS section to interface it to 2 chips [MT41K128M16] -32-bit data width.  we are planning to use one more DDR3 component to support ECC.
Please let us know the DDR3 controller pins details in XC7Z020 PS including ECC pin details.
Pench
vsrunga
HI,
I do not think there are separate ECC pins, please visit below link and go to ASCII files for pin loations of your package
http://www.xilinx.com/support/documentation/user_guides/ug865-Zynq-7000-Pkg-Pinout.pdf
http://www.xilinx.com/support/packagefiles/z7packages/xc7z020clg484pkg.txt
http://www.xilinx.com/support/packagefiles/z7packages/xc7z020clg400pkg.txt
Also go through below AR for ECC test example design
http://www.xilinx.com/support/answers/58684.html
Hope this helps
-Vanitha
kpench
Thanks for the info.
I could not able to find any dedicated DDR3 ECC pins in the package.
Is it will be internally supported?
Please let me know.
Pench
vsrunga
Yes, there are no dedicated ECC pins,  controller takes care of the opeartion. PSDDR uses lower 16bit as data and few higer bits for ECC.
Please refer UG585  0.8 Error Correction Code (ECC) section for more details.
Hope this helps
-Vanitha
kpench
U mean no need of external DDR3 component for the ECC operation right?
Pench
vsrunga
External DDR3 interface and data is needed but the component by itself do not play any role in ECC functionality, it stores all normal data and ECC bits as data
Vanitha
