Zynq702 : TRD Xapp1167 : bitstream error
Hi, I am new to Xilinx, thats why I planned on using Xapp1167.
when I am trying to create bitstream without any changes from my side, there is a bitstream error.
Total memory usage is 624964 kilobytes
Number of errors   :    0 (   0 filtered)
Number of warnings :   57 (   0 filtered)
Number of infos    :    4 (   0 filtered)
ERROR:EDK:546 - Aborting XST flow execution!
INFO:EDK:2246 - Refer to
   c:\Dropbox\xapp1167\xapp1167_ise\sw\posterize\xps_proj\synthesis\system_vtc_0
   _wrapper_xst.srp for details
Writing NGCBUILD log file "../system_clock_generator_0_wrapper.blc"...
NGCBUILD done.
INFO:EDK:3509 - NCF files should not be modified as they will be regenerated.
   If any constraint needs to be overridden, this should be done by modifying
   the data/system.ucf file.
Rebuilding cache ...
ERROR:EDK:440 - platgen failed with errors!
make[1]: *** [implementation/system.bmm] Error 2
make[1]: Leaving directory `c:/Dropbox/xapp1167/xapp1167_ise/sw/posterize/xps_proj'
ERROR:EDK -
   Error while running "make -f system.make bits".
Attached system_vtc_0_wrapper_xst.srp file.
Any input will be greatly appreciated. Thank you.
pvenugo
Hi Aditya,
Do you still encounter this error?
Praveen
yes praveen, did u face this before ?
thanks,
Aditya
