expertengr
changing user name or display name
hello, is it possible to change user name or display name on all future and previous posts ?
thakurr
Hi @expertengr
Refer this link:
https://forums.xilinx.com/t5/Welcome-Join/Frequently-Asked-Questions-Welcome-and-Join/m-p/817390#M51279
Hope this helps.
Rohit
Rohit
thakurr
Hi @expertengr
Refer this link:
Hope this helps.
Rohit
Rohit
florentw
Hi @expertengr,
If everything is clear for you on this subject, please mark thakurr response as solution.
Best Regards,
Florent
Florent
robforester
Thank you so much for let us know the process. I will try for it.
sean_nijjar_1991
I realize this is an old post, but it appears that the linked to help article has been deleted. Is it still possible to change forum display names?
stacias
Administrator
Administrator
@sean_nijjar_1991
Unfortunately, due to our Signal Sign-on, we are not able to change your username (during account registration it states that your username will be visible in Forums).
Your options are:
 1.) Delete your account Xilinx.com account and create a new account with different username. Please be advised that deleting your account will disable any software licenses associated to that account.
You can request that your Xilinx account be deleted by filling out the following form: https://www.xilinx.com/content/xilinx/en/about/feedback/website-feedback.html
2.) Create a second Xilinx.com account using a different email address (and different username) for Forums activity.
Don’t forget to reply, kudo, and accept as solution
