checking if registers are in IOB
Using windows vivado 2016.2. I want to check in batch mode if/which regs have gone into the IOB's.
I have followed http://www.xilinx.com/support/answers/62661.html
I can get the 'IO Reg Type' column in the gui report timing summary following the instructions above as per attached file.
However, I cannot get the IOB information out on a report file using -batch mode tcl scripts. I've tried...
    report_datasheet -file $outputDir/post_route_datasheet.rpt
....and....
    report_timing_summary  -file $outputDir/post_route_timing_summary.rpt -delay_type min_max -report_unconstrained     -check_timing_verbose -max_paths 10 -input_pins -datasheet -name timing_1
....and.....
      report_io -file $outputDir/post_route_io.rpt
Is it possible to get a report of check that will indicate if regs are in IOB's? I have attached my  simple project.
.......Steve
Re: checking if registers are in IOB
HI @steve_farmer
There is no inbuilt tcl command for this as of now.
You can go to Tool--> Xilinx Tcl store. and Install Ultrafast Design Methodology kit. (as shown in the attachment)
The following command  will output a table in which the last column shows the IOreg info for each port.
xilinx::ultrafast::report_io_reg
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
HI @steve_farmer
Bharath
Downloaded the app from the TCL store as suggested and added this line to my tcl build script after place and route.....
xilinx::ultrafast::report_io_reg -verbose -file $outputDir/post_route_iob.rpt
...and I now have a report that indicates whether pin IOB's are being used.
I am still surprised this isn't part of the standard pin/io reports but I supposed this is exactly what the TCL store is for.
Thanks....Steve
Scholar drjohnsmith
were all amazed its still not built in in the standard report.
but hay,with TCL  you can do everything,
Newbie ncubed01
This script is not compatible for Xilinx Zynq Ultrascale+ MPSOC. How come we cannot perform this simple task with Vivado? ISE was  better at this task than Vivado. place_report_io should list which I/O is in the IOB by default!
What is the solution for Xilinx Zynq Ultrascale+ MPSOC?
Here is my output from running this tcl script:
INFO: [Common 17-660] Loading Tcl app 'ultrafast' into namespace {xilinx::ultrafast}
xilinx::ultrafast::report_io_reg -verbose -file ./results/io_regs.rpt.rpt
-E- architecture zynquplus is not supported.
-E- some error(s) happened. Cannot continue
Scholar drjohnsmith
With TCL and scripts, u can solve anything.
Ah my days on UNIX and VMS are not wasted.
