zhh839725969
dds amplitude problem
hello everyone,I have a problem.When I design the DDS IP CORE,I do not know how to creat different amplitude of sin waves.Usually I could creat the same amplitude but different frequency sin wave to be superimposed.However,I do not know how to achieve amplitude control.And what is the function of SFDR? Thank you!
bwiec
You don't control the amplitude in the IP core itself. You'd use a multiplier on the output to scale it appropriately.
www.xilinx.com
bwiec
www.xilinx.com
saradapr
Hi @zhh839725969,,
Please check page 11 for changing the amplitude.
https://www.xilinx.com/support/documentation/ip_documentation/dds_compiler/v6_0/pg141-dds-compiler.pdf
Sarada
Please mark the Answer as "Accept as solution" in case it helps resolve your query.
Give Kudos to a post which you think is helpful and informative.
