download xilinx ise
Dear All,
I am having a problem downloading xilinx ISE .
I am receiving the following error
We cannot fulfill your request as your account has failed export compliance verification.
Can you please help solving this problem.
Check the following AR https://www.xilinx.com/support/answers/44043.html
Thanks for your reply , I am not from an embargoed destination , I used to download software normally from xilinx before . Kindly can you please elaborate.
Try with some other web browser.You can request the ISE DVD.
https://www.xilinx.com/support/dvd-fulfillment-req-ise.html
I tried several browsers and Pcs and same issue , this is strange is there any other link or download site to download the xilinx ise .
i xilinx for programming purpose of running vhdl program how could i get the setup.i am college student
Advisor
Advisor
@pranavs You need to make a Xilinx account. In that you will need to put in complete, correct details - these do get checked and if you leave (for example) the address blank then Xilinx will not be able to provide software to you.
Then, assuming that you're from a country that the USA is currently friendly towards (ie not Iran, North Korea, etc) you should be able to download Vivado with no problems. If you are from one of the unfriendly countries, then Xilinx is not legally allowed to provide the software to you.
Thank u 4 every thing
