sophia_123
fail to debug XADC on board using external voltage
I am using XADC on Zybo board in PL.an external valtage in 0~1v is used. A simulation on the XADC is successful to be done,the results of transformation are correct. However, when I connect a external power to the pin, the result as showed on LEDs is wrong.Is it the constraint wrong?
My constraint is as follows.
the pin1 as vauxp0 is connected to external power.
the pin7 as vauxn0 is connected to GND.
the pin2 as vp is connected to GND.
the pin7 as vn is connected to GND.
Sophia
sophia_123
the above description has a little wrong, the following is right.
the pin8 as vn is connected to GND.
sandrao
Community Manager
Community Manager
How do you have the AUX IOs instantiated at the toplevel of the design? This is a Virtex-5 AR but its still true for 7 Series
https://www.xilinx.com/support/answers/29240.html
The AUX IOs have to be called out at the toplevel of the design. If you are using Vivado you need to also give them a LOC and IOSTANDARD.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
