failure to "use" packages - sometimes (ISE Webpack 14.6)
I have a project that synthesizes fine for the Virtex-5 XC5VLX50T-2. It includes a settings.vhd package with definitions of constants and types that are used by all of the modules, with a "use settings.all;" at the top of each. The settings file has the source settings with the global compile checkbox set (can't remember the exact name).
If I change the project in any of a number of ways, it does compile the settings.vhd file first, indicating that the package and package body have been processed - but then when compiling the first module that "use"s the settings file, it says "<settings> not defined" and fails because the definitions from settings.vhd are not used.
This problem occurs
1. If I just change the speed grade from -2 to -3
2. If I just change the target chip to a Kintex-7 or Artix-7 that are explicitly allowed for the Webpack (e.g. XC7K160T)
3. Even after I cleanup the project files, or create a new project with the same sources.
4. If I write a testbench and try to use ISim.
5. Even if I move the settings.vhd file to a declared library folder
If I change back to the original Virtex-5 target, or a different permitted virtex-5 target with the default speed, the project works fine again.
Seems like a bug that at the very least involves an incorrect error message.
Historian
Historian
Re: failure to "use" packages - sometimes (ISE Webpack 14.6)
Your problem is that your use clause doesn't indicate into which library you've analyzed your package.
By default, assuming you do nothing special, every source file, including the file which has your package, is analyzed into the work library.
So the correct use clause is:
use work.settings.all;
That oughta do it.
Can you share the test case, does it contain any IPs?
And is this specifically with webpack license?
Vanitha.
Historian
Historian
That oughta do it.
