Visitor hr92
fatal error: bits/predefs.h: No such file or directory
I was trying to build the opencv linux application example on SDK. I added the Root File System path (Linaro) and I tried to compile but I got this error:
...../features.h:324:26: fatal error: bits/predefs.h: No such file or directory
 #include <bits/predefs.h>
compilation terminated.
Re: fatal error: bits/predefs.h: No such file or directory
Hi @hr92,
Please
You needed the proper libc includes for 32-bit builds. if You are running a 64-bit machine. So you should use below commend
sudo apt-get install libc6-dev-i386
https://ubuntuforums.org/showthread.php?t=1877944
Sarada
