Observer mao_jacky
generate the cdc file, and the tool stop work
Hi, all
  I want to generate a cdc file for chipscope, but when I click the button “the Return To Project Navigator”, and the tool is stop to work, and remain at the interface, the interface as follow:  generate cdc file
PC system version: windows 7 64bits
ISE version: ISE 14.7
    who can tell me the reason ? Thanks
Observer mao_jacky
Re: generate the cdc file, and the tool stop work
I reinstall the operating system(change Win7 64 Bits to Win7 64 Bits sp1), and the problem is solved.
Thanks for your attention.
Hi @mao_jacky
Is this consistent?
Try using a example design and see if this behavior is specific to the project.
Thanks,Vijay
Hi @mao_jacky,
Can you please try running chipscope core inserter standalone?
In windows start menu go to All programs->Xilinx Design Tools-> ISE Design suite 14.7->Chipscope pro-> Chipscope 64-bit->Core inserter
Arpan
Arpan
Observer mao_jacky
This is consistent. If I direct to close the interface, the ISE always show "opening: ***.cdc", and can't to stop. Why?
Hi @mao_jacky,
Did you try standalone?
Arpan
Arpan
Observer mao_jacky
I has tried, but the problem is't solved. Could it is cause of the system compatibility?
Hi @mao_jacky,
May be it has to do with installation.
Because windows-7 64bit professional is supported in ISE 14.7.
Arpan
Arpan
Hi @mao_jacky
Do you have another machine to rule out machine dependent issues?
One more possibility is a bad/corrupted installation. Try re-installing the software.
Thanks,Vijay
Observer mao_jacky
Hi @mao_jacky,
Glad to know your issue is resolved.
Please close this thread by marking accept as solution to the answer that addressed your query.
Arpan
Arpan
