help me . I want petalinux version that supports virtex 2 pro.
I want  petalinux version that support virtex 2 pro.
Re: help me . I want petalinux version that supports virtex 2 pro.
Hi @yanaton2537,
Virtex 2, Spartan 2 and all the older parts were supported till ISE 10.1 which do not have Petalinux supported versions.
 Just curious to know why you want to use such an old device with Petalinux?
--Syed
Hi @yanaton2537,
--Syed
thank you.
Additional data FYI: To know more about PetaLinux Support and Resources refer
http://www.xilinx.com/tools/petalinux-license.htm
