bamerni
help with logiIP core FIFO design
I design a FIFO using LogiIP core
when I just want to test it the output data didnt read the first data in
what is the wrong with this fifo
and how can I read the first data in after 4 clok cycle
what change should I do in the steps of the LogiIP core design to make the output data read from first data in
avrumw
Guide
Guide
You need to wait a number of clocks after the deassertion of rst before you start pushing (wr_en) the first word of data into the FIFO. The number of clocks is "small-ish", and should be documented in the core's datasheet, but it isn't immediate.
Simply wait (say) 16 clocks after the deassertion of rst before you do your first wr_en, and the FIFO will operate correctly.
Avrum
avrumw
Guide
Guide
Avrum
gszakacs
Professor
Professor
In the simulation as posted, it's obvious that the FULL flag is active due to reset at the start of simulation.  Note that GSR is applied for the first 100ns of simulation by default, so anything using Xilinx cores or primitives will remain reset during that time regardless of other inputs.  In any case, the FIFO cannot be written when FULL is asserted.  Write enable is effectively
WR_EN and not FULL
-- Gabor
bamerni
thank you both Mr. Avrumw and Mr. Gszakacs
you are rigth
i find that the full signal is fulldown at the positive edge of the third clock cycle after the reset signal fulldown whatever the duration of the clock cycle and whatever the width of the word.
