bamerni
how to calculate the hardware utilization
Dear All
my supervisior ask me to calculate the hardware utilization of my design
Can one get this information from the synthesis report of the ISE Design suite
htsvn
The resource utilization will be a part of the map report after implementation. Check for <design_name>.map file
An example attached with this post.
--hem
htsvn
--hem
siktap
You can get this information in synthesis. But the final utilization is reported in the par report(.par file).
This is the final utilization thats gets converted to bit file.
Sikta
