how to determine configuration row/column
sorry this seems like a obvious question but how do you declare row and column in verilog.
For example 10 rows 2 columns.
Re: how to determine configuration row/column
i was think it something like this?
input row_column [5:0][0] //6 rows 1 column
Community Manager
Community Manager
Yes this looks correct for 6 rows and 1 column.
Guide
Guide
Careful...
reg  row_column [9:0][1:0]
gives you a  2 dimensional array of 1 bit quantitie; i.e. twenty x 1 bit quantities.
More likely, what you want is
reg [1:0] row_column[0:9];
This gives you 10 words each of 2 bits; i.e. ten x 2 bit quantities.
The big difference between these is if you use
wire [1:0] b;
assign b = row_column[3];
this assigns the 2 bit quantity in "row" 3 to the 2 bit value b, but only if you use the latter definition - if you use the first definition, then this is a syntax error - you can only access individual bits of the array
assign b[0] = row_column[3][0];
assign b[1] = row_column[3][1];
Avrum
