how to handle of EMC within axi4lite interconnect?
Hi.
My system consisted by axi4lite interconnect and I'm trying to use AXI_emc.
But especially, there was mismathced port.in emc. For instance,  axi_emc have s_axi_mem_arlen, burst, ... these signal do not contain in axi4lite.
So who to control, The EMC ip withon axi4lite architecture?
Re: how to handle of EMC within axi4lite interconnect?
@balkris
The block memory generator fixed with wea[3:0] instead of wea[0:0]
Axi_emc have wea[3:0] not wea[0:0]
How to handle this problem?
check this core
http://www.xilinx.com/support/documentation/ip_documentation/axi_emc/v3_0/pg100-axi-emc.pdf
Thanks and Regards
Balkrishan
@balkris
BMG need only single bit for write enable so you can just add too extra bit . You may add extra logic Wea[3:0] < = "111" when wea_bmg = 1 else
Wea[3:0] < = "000";
Thanks and Regards
Balkrishan
Also i have one more question bout the emc.
My emc's s_axi_reg_awaddr and s_axi_awaddr is just [4:0].
How to get 32 bits address?
