Visitor zly
how to measure C program running time on microblaze standalone?
How can I measure the execution time of the C code on microblaze? no OS is used so I can not use desktop C funcions in time.h, do I have to use xps timer or axi timer? Can any one give a tutorial or example using xps timer to measure execution time?
Historian
Historian
Re: how to measure C program running time on microblaze standalone?
The easiest way to do this is to set an output pin right before a particular function of interest is called, then clear it once the function returns, and monitor that pin on an oscilloscope.
You can make use of counters/timers. Start a timer at the start of the program and stop it just before finishing the program. Find the difference. Multiply the number with the time period of clock. I think microblaze runs in 100 MHz. So multiply with 1/(100*10^6).
Paul
