how to write a standard_logic_vector values into a file
hi
I am using a FFT ip core. And my result is stored in m_axis_tdata which is a 16 bit std_logic_vector. Can anyone suggest me how to get all the values of m_axis_tdata for 32 point FFT into a Text file or a binary file,
thank u.
Hi gaonkar@123,
You can insert ILA and export ILA data to .csv file.
Arpan
gaonkar@123 check this out: http://web.engr.oregonstate.edu/~traylor/ece474/vhdl_lectures/text_io.pdf for simulation. For hardware capture use an ILA as @arpansur suggests.
Hi gaonkar@123,
Were the suggestions provided helpful?
Arpan
