saddam.sarwar
.hyp file for virtex5 fpga board
hey guys
i need .hyp file of virtex 5 fpga board for my final year project. i will be very thankful to you!!
thanx
venkata
check here
http://tgoogle.xilinx.com/search?output=xml_no_dtd&ie=UTF-8&oe=UTF-8&client=support&proxystylesheet=support&site=Answers_Docs&filter=0&resultsView=category&tab=bk&num=1000&sortBy=date&show_dynamic_navigation=1&sort=date%3AD%3AR%3Ad1&documentClass=Doc...
saddam.sarwar
i did not find the required file... if u know any other link then please let me know.
mcgett
You added the same request to 5 other threads in the forums that are completely unrelated to your post.  Please do not do this as it is bad forum etiquette.
You never said what Virtex-5 board you were interested in, but if it is a Xilinx designed Virtex-5 board such as the ML501 or ML505 then HYP files are not made available for the boards.   If it is a 3rd party board then you will need to ask that company directly.
