internal error
i wrote a code for hash program which shows internal error while synthesis. But simulation works well. Anyone please tell me the solution for correct it.
Is it a problem if i using multiple for loops(2 dimensional) inside always block?
Thanks in advance......
Re: internal error
p,
Without posting your code, or the error message, are we suppoosed to guess what you did wrong?
OK:  here goes.  You made a spelling error.
That wasn't it?
OK, we will try again:  you are writing HDL code, not c code.  Think hardware, not software.
Austin Lesea
Principal Engineer
Xilinx San Jose
Re: internal error
sir,
  i have error like...
INTERNAL_ERROR:Xst:cmain.c:3464:1.56 - Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
and i have uploaded my code... please tell me the solution to solve it..
Re: internal error
p,
Well, googling on that error, I get about 608 results.  Most of them have to do with a bug in the code, so XST gives up, and exits.
The good news:  you probably have made a very basic error.
The bad news:  you have to go find it.
Austin Lesea
Principal Engineer
Xilinx San Jose
