ip core reed solomon encoder v9 without axi4
Is it possible to use logic core ip reed solomon encoder version 9 with AXI4 interface.
regards
Rose Varghese
Re: ip core reed solomon encoder v9 without axi4
@rosepadayatty why is axi4 undesirable ? and what are you trying to accomplish by removing it?
i am not interfacing anything with rs encoder. i simply want to include that in my design. so i dont want AXI4.
@rosepadayatty this core seems to use axi-stream for input & output. If you configure it properly there is no control interface. What axi4 interface do you want to remove? axis streams are necessary to use the ip.
In vivado the core only supports AXI4 Stream interfaces and there is no non axi interface option available.
You need to drive the data through AXI4 stream when this is integrated to your design.
Satish
