Observer nag.chil
memory module not found when using command prompt
Hi hello..
As shown in the figure below my hierarchy is..
When i synthesize in GUI it is successful.
But When i do in command prompt. It shows an error like this
Elaborating module <PIO_EP_MEM_ACCESS>.
ERROR:HDLCompiler:1654 - "../example_design/PIO_EP_MEM_ACCESS.v" Line 131: Instantiating <tx_mem_i> from unknown module <tx_mem>
Module PIO_EP_MEM_ACCESS remains a blackbox, due to errors in its contents
WARNING:HDLCompiler:1499 - "../example_design/PIO_EP_MEM_ACCESS.v" Line 78: Empty module <PIO_EP_MEM_ACCESS> remains a black box.
So can anybody say what the problem is, ....?
Re: memory module not found when using command prompt
@nag.chil
Try regenerating the tx_mem_i core and see if it helps.
You may also try -sd command line option. Refer https://forums.xilinx.com/t5/7-Series-FPGAs/error-HDLCompiler-1654-when-instantiating-Synpfy-pro-edf-file-to/td-p/369577 on similar issue.
Sravanthi
@nag.chil
Sravanthi
Observer nag.chil
Thankyou for ur help @svanapar...
It worked...Not with -sd switch...but with deleting existing cores and regenerating cores...
