Visitor peppe84
microblaze c++ libraries
hi,
i read some posts about c++ projects and libraries problems on microblaze and then i have a question: is necessary edk license to add c++ libraries and features to a software project on microblaze? what is the correct library to use string type in c++ project? i can't use the string type in my sdk project... :( help me, please.
thanks
Visitor peppe84
Re: microblaze c++ libraries
it's important for me because i have wrote a c++ project that works very well on PC and now i have to adapt and pass it on FPGA
Scholar sampatd
There is no separate license required to create C++ applications.
Which version of SDK are you using, if it is 14.7 then there is a known issue when making C++ application:
http://www.xilinx.com/support/answers/57865.htm
SDK comes installed with the C++ standard platform library (libstdc++.a), which is required by the mb--gcc compiler. This library contains standard language classes such as sting manipulation.
Follow the below procedure to make a new C++ project:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/SDK_Doc/reference/sdk_u_new_proj_wiz_m_name.htm
