Visitor persona215
microblaze tutorial failed
I'm trying to make sample design using microblaze, so i read and follow steps on "ug940-vivado-tutorial-embedded-design.pdf" document.
All step options matched that document, but i faced error massage during step9, "Creating a freeRTOS “Hello World” Application"
At number 6 at step9, this message poped up.
and SDK.log writen below lines
71 15:20:15 ERROR :  [Hsi 55-1594] Core standalone of version 3.03.a not found in repositories
72 CRITICAL WARNING: [Hsi 55-1564] TCL file /home2/jikim/Vivado_test/ug940-design-files/sysrtos/lib/bsp/freertos_v2_00_a/data/freertos.tcl doesn't exist for driver freertos
73 invalid command name "xget_libgen_proc_handle"
74  [Hsi 55-1545] Problem running tcl command ::sw_freertos_v2_00_a::kernel_drc : invalid command name "xget_libgen_proc_handle"
75     while executing
76 "xget_libgen_proc_handle"
77     (procedure "::sw_freertos_v2_00_a::kernel_drc" line 2)
78     invoked from within
79 "::sw_freertos_v2_00_a::kernel_drc freertos"
80  [Hsi 55-1440] Error(s) while running DRCs.
81 15:20:15 ERROR : Error generating bsp sources: Failed to generate BSP.
how can i fix this problem?? i used VIVADO 2015.2 version..
Thank you
