no reception of UDP frame on wireshark
I am trying to communicate to pc using fpga board  ml507 virtex 5 .
In my program, when I send data that I've entred manually in the program it works, but when I replace that same data with a sinus ( DDS ip in core generator ) there is no communication, I can't find a thing on wireshark. I can still find my frame on chipscore. Do you have any explication ?
Thank you.
what is the status of ethernet link during the failure?
