shahid
petalinux not creating uio
I want to use UIO for PL. For that i have make
compatible = "generic-uio";
in kernel configuration i have
<M> Userspace I/O drivers  --->
<M>   Userspace I/O platform driver with generic IRQ handling
<M>   Userspace platform driver with generic irq and dynamic memory
but when is built the petalinux it does not creates /dev/uio0.
I have tried petalinux 2015.4 and petalinux 2015.2.
An other problem is that when i used petalinux 2014.4 it does not shows interrupt in device tree but it creats /dev/uio0.
Please help me.
Tags (3)
shahid
Hi zhangdefu,
What you have said is right. You have to edit system-conf.dtsi you will see following line there
chosen {
bootargs = "console=ttyPS0,115200 earlyprintk ";
so you just replace it by
chosen {
bootargs = "console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio";
It will definitely work.
If you need more help let me know.
jeffdaq
The uio driver does not support that compat string.  You either need to modify the uio driver to add that string or I've also seen it suggested that you can modify the kernel cmdline to enable the uio(sorry, I didn't do this so don't know the exact string)
jeff
shahid
 Hello  jeffdaq,
Thanks for your reply.
you mean to say Petalinux 2015.4 uses different compat string for generating uio?
when i have used petalinux 2014.4 it genertes node for device using compatible ="generic-uio".
But petalinux 2015.2 and 2015.4 both i have tried but they are not making nodes for device. I have enabled kernel cmdline for uio.
Waiting for your reply.
shahid
Found the solution.
1. petalinux-config -c kernel
boot options--> kernel commandline type ---> "extend bootloader kernel arguments"
select this option.
2. In system-top.dts
chosen {
verify with cat /proc/cmdline.
zhangdefu
Soory. I am new here. You said:
In system-top.dts
chosen {
Do you mean edit system-top.dts and add these lines at the end of the system-top.dts file? I did it and got syntactic error. How to do "chosen" exactly? Thanks.
From u-bbot, I did
setenv bootargs console=ttyPS0,115200 earlyprintk uio_pdrv_genirq.of_id=generic-uio
and checked after system boot
cat /proc/cmdline
But, it still does not work.
shahid
Hi zhangdefu,
chosen {
chosen {
zhangdefu
shahid:
It works ! I got the UIOx generated and works in polling mode.
Do you know where can I find UIO interrupt sample C code and kernel/device-tree configuration guide ?
Thanks a lot.
yerby
Sorry but this solution is not working for vivado/petalinux 2016.4 on ubuntu16.04.
The linux kernel is 4.6.0. Running petalinux-config -c kernel, but resuts that under "Boot options" there is no "kernel commandline type" option.
I do have edited system-conf.dtsi to modify
with
but still does not work. No /dev/uioX devices are created (and I should have 3, a custom core and two gpios).
Please, any hints?
Best regards
yerby
Hi again,
Just to clarify that the problem seems to be specific to the UIO devices, because I have checked that the hw has been inferred correctly and it is working:
# ls /proc/device-tree/amba_pl
total 0
-r--r--r--    1 root     root             4 Mar  2 08:53 #address-cells
-r--r--r--    1 root     root             4 Mar  2 08:53 #size-cells
drwxr-xr-x    5 root     root             0 Mar  2 08:53 .
drwxr-xr-x   10 root     root             0 Jan  1  1970 ..
-r--r--r--    1 root     root            11 Mar  2 08:53 compatible
drwxr-xr-x    2 root     root             0 Mar  2 08:53 gpio@41200000
drwxr-xr-x    2 root     root             0 Mar  2 08:53 gpio@41210000
drwxr-xr-x    2 root     root             0 Mar  2 08:53 mysum@43c00000
-r--r--r--    1 root     root             8 Mar  2 08:53 name
-r--r--r--    1 root     root             0 Mar  2 08:53 ranges
And I can control leds with:
# devmem 0x41200000 32 0x000000ff
# devmem 0x41200000 32 0x00000000
and read switches with:
# devmem 0x41210000
Thanks in advance for your advise.
Regards.
marcoventurini
You have to edit the system-top.dts file in the meta-user/recipes-dt/device-tree/files/ folder.
/dts-v1/;
/include/ "system-conf.dtsi"
  chosen {
		stdout-path = "serial0:115200ns";
The system-conf.dtsi file is in the generated layer so it will be overwritten by the toolchain.
Marco
madhuba
hi
Edit the file
meta-user/recipes-dt/device-tree/files/system-user.dtsi
and add the  bootargs
  chosen {
it works for 2017.3 Petalinux builds
Madhubala
