possible to allocate 64K bytes of data in artix 7 series FPGA
can any one tell me Is it possible allocate 64K bytes of data in artix 7 series FPGA? and how do I allocate?
Hi @honnappabr,
You can use BRAM.
Arpan
BRAM will use 32 kilo bits. I need 64 kilo bytes
Hi @honnappabr,
You can cascade BRAMs .
Please go through page-120 onwards on http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug901-vivado-synthesis.pdf
You can modify the depth and width in the templates given in UG901, tool will infer BRAM if the values are above the threshold.
Arpan
Advisor
Advisor
The block RAMs store 32 kilobits each. To store 64 kilobytes, you simply put two in series (two block RAMs can work together to give you a 64 Kbit array), and then put eight of those in parallel. A total of 16 block RAMs for 64KBytes.
