ajasan
problem launching modelsim with vivado 2013.4
I'm trying to run simulation using Modelsim simulator in vivado tool.
I face the following problem.
whenever I click the RUN BEHAVIORAL SIMULATION option, prompt saying "LAUNCHING MODELSIM" opens up and disappears and nothing happens after that.
The project summary is also not getting updated.
Has anyone faced the same problem or suggest what can be the resolution given?
vemulad
Did you set the modelsim executable location in Tools --> Options in Vivado IDE? See below
Deepika.
Deepika.
vemulad
Is the modelsim GUI not opening after this? If yes, there could be license problem. Did you setup the modelsim license properly?
Check the Vivado console and command prompt  from where the tool is launched for details on failure.
Deepika.
Deepika.
ajasan
Thank you Deepika for your suggestion.
ajasan
License is not a problem. ModelSIM is opening independently. but unable to invoke from Vivado.
vemulad
Did the log give any info?
Deepika.
Deepika.
ajasan
no. it is dispalying nothing.
vemulad
Deepika.
Deepika.
ajasan
thank you Deepika. it worked. But I would like to notify that, in another PC, where Vivvado is installed, "QUESTASIM/MODELSIM PATH: " is left empty and still it is working. can you explain why?
vemulad
Do you have MODELSIM environmental variable set on that other machine? May be that's making it work.
Deepika.
Deepika.
ajasan
Might be. thanks for your clarification.
Asan.
