"Reboot" can't restart the system in QSPI startup mode
   I have succeed in booting linux-3.15 from 32MB-qspi flash on custom board.I Put the boot file before 16 MB space, after 16 MB of space is user data.When I use the "reboot" command, the system will not be able to restart,But re switching power supply can start the system.
   After the "reboot" command stop here:
   The system is going down NOW!
   Sent Swatchdog watchdog0: watchdog did not stop!
   IGTERM to all processes
   Sent SIGKILL to all processes
   Requesting system reboot
   reboot: Restarting system
   Does anyone know why?
   Thanks in advance for any ideas.
these ARs may help
http://www.xilinx.com/support/answers/55572.html
http://www.xilinx.com/support/answers/52538.html
http://www.wiki.xilinx.com/Prepare+Boot+Medium
Thanks and Regards
Balkrishan
