"Startup clock for this file is CCLK instead of JTAG CLK. Problems will likely occur. Associate config file with device anyway?"
I'm running v. 14.7 on a Windows 7 platform.
The board I'm trying to program is a Spartan XC3S500E.
I've made a very simple program, no warnings, no errors.
When I try to program the board using Adept 2.1, I get this error message:
If I click "yes", the program will load, but it won't run.
I've read in posts related to earlier versions that this can be fixed by changing the startup clock option to jtag, but I can't find that setting anywhere.  Where is it??
Teacher eteam00
Re: "Startup clock for this file is CCLK instead of JTAG CLK. Problems will likely occur. Associate config file with device anyway?"
I am using ISE version 14.6.
Perhaps you might find the correct settings menu under "bitstream settings" (see leftmost margin).
-- Bob Elkind
SIGNATURE:
Summary:
Teacher eteam00
That's the device on the board.  Which board are you using?  Is it the Digilent Nexys2?
If you are in ISE Project Navigator:
  1. In the Hierarchy pane select the top level source file
  2. In the Processes pane select the "Generate Programming File" process
  3. Mouse right-click brings up an options menu, select "Process Properties"
  4. In the Process Properties Startup Options window, you will see the config options you seek.
-- Bob Elkind
SIGNATURE:
Summary:
Thanks for your reply.
Yes, it is the Nexsys2.
...and that's exactly what I've read before.  Either it's something real obvious that I'm missing, or you're talking about a different version than the one I'm using (14.7).  Nothing happens if I right-click "Generate Bitstream", and there is no "Process Properties Startup" menu anywhere that I can find under "Bitstream settings".  I've attached a printscreen.
Teacher eteam00
-- Bob Elkind
SIGNATURE:
Summary:
