"Your XILINX environment variable is undefined" / Planahead 14.7/Windows 7/Webpack
I downloaded and installed the webpack, with no issue during installation.  When I start PlanAhead 14.7, I get the following error message:
"Your XILINX environment variable is undefined. You will not be able to run Synthesis and Implementation using ISE based strategies, or import ngc netlists. Please setup your XILINX environment to get full functionality."
I ran the settings32.bat file as per the instructions in the manual, and it makes no difference.
I tried adding an environment variable called c:\xilinx (as I've seen on another), and I get "\xilinx\bin\common\bin does not contain 64bit files", or something along those lines.  I notice there's a user variable called "No_Xilinx_Data_License" (the value of which says "hidden"), even though I do have a valid .lic file that I specified in the license manager.
What am I doing wrong?  This is getting quite frustrating...I'd much rather be doing VHDL than fighting PlanAhead and Windows for hours trying to make them work together.
Scholar sampatd
Re: "Your XILINX environment variable is undefined" / Planahead 14.7/Windows 7/Webpack
What kind of license do you have?
Make sure the license files are installed properly. Check pages 51 and 52 of the following guide to install the license correctly
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
Scholar sampatd
