reset sequence
What is the signals reset sequence, program_b(bank0),ps_pro_b(bank500) and ps_srst_b(bank501) of zynq 7020 ? Thanks
thakurr
Refer below link of UG if it helps.
http://microzed.org/sites/default/files/documentations/MicroZed_HW_UG_v1_4.pdf
Also refer to this AR on sequencing for SRST and por signals.
https://www.xilinx.com/support/answers/52847.html
Rohit
Rohit
thakurr
Rohit
Rohit
