routing conflict
I am seeing below error messages while routing phase
Routing Conflict 1:
    Net:array<1> on pin ADDRATIEHIGH1 on location RAMB18_X6Y34
    Net:array<0> on pin ADDRATIEHIGH1 on location RAMB18_X6Y35
    Conflict detected on wire: PINFEED(-34123,-98345)
arpansur
Hi @xilinxhelpneeded,
We have seen this issue when two different RAMB18 blocks try to lock on same RAMB36 site.
As a workaround
Try to manually place the RAMB18 block to the required sites.
Arpan
Arpan
anusheel
@xilinxhelpneeded
Can you open the design in FPGA editor and check the nets and their connection to validate the error?
Anusheel
Helpful answer -> Give Kudos
vemulad
You can assign different block names to the BRAM instances using BLKNM constraints. Refer to page-60,61 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/cgd.pdf
Deepika.
Deepika.
vemulad
Is this issue resolved?
Deepika.
Deepika.
