Visitor oscarseijo
switching 2 clocks in the same process
Hi everyone,
I am involved in a project in which I need to switch between 2 clocks to acces one memory. So I have a switch signal to change the clk when I need. Here is the problem, it doesnt switch correctly. I have done dozens of changes (for example trying with only one clock), but with the same result. In the simulation works correctly, but it doesnt in my fpga (spartan 6 LX9).
It starts at state 1 (clk1, switch='0'). Then it changes from state 1 to state 2 (clk2, switch='1') and finally switches again to the state1. Then the states never switch again.
The problem is in the change from the state 2 to state 1. For example, if it starts in the state2 (switch='1') it never goes back to the state2.
You can see here the code:
echo: process(clk1,clk2)
begin
        if (rising_edge(clk1)) and (switch='1') then     --State1
            if (cont1 = 500) then   --cont1: counter of the state1
                 switch<='0';
                 FULL<='1';
                 cont1<=0;
            elsif(cont1 /= 500) then
                 cont1<=cont1+1;
            end if;
          end if;
        if rising_edge(clk2) and (switch='0') then --State2
            if (cont = 500) then  --cont: counter of the state2
            switch<='1';
            FULL<='0';
            cont<=0;
          elsif (cont /= 500) then
            cont<=cont+1;
            end if;
        end if;
end process echo;
When I tried with the same clock happened the same
echo: process(clk1)
begin
            if (cont1 = 500) then   --cont1= counter of the state1
                 switch<='0';
                 FULL<='1';
                 cont1<=0;
                 cont1<=cont1+1;
            end if;
          end if;
        if rising_edge(clk1) and (switch='0') then --State2
            if (cont = 500) then  --cont= counter of the state2
            switch<='1';
            FULL<='0';
            cont<=0;
            cont<=cont+1;
            end if;
        end if;
end process echo;
In this second case I can join the two rising_edge if conditions because it has the same clock. When I do that, it finally works, but it is not useful.
Any idea? I have lost more than 10 hours in this ****.
Thank you very much for your attention.
Óscar.
Scholar austin
Re: switching 2 clocks in the same process
o,
I suggest you look at the BUFGMUX primitive.  It allows you to switch between clocks without creating a runt pulse, or glitch.
Switching between asynchronous clocks is the most dangerous of tasks.  It at all possible, I would always use the best clock, and synchronize the results with the other clock (if needed).
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor oscarseijo
I almost forgot, one clock works at 50 MHz and the other at 1 MHz and they are TOTALLY independent, one clock comes from an external system (1 MHz) and the other is the internal.
Scholar austin
o,
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor oscarseijo
After posting I made some changes in my design. As you say, I used the fast clock to 'sample' the slower one and see the edges.
if the preview sample was 0 and the new is '1' I know there is a rising edge. If the preview sample was 1 and the new is 0 I know there is a falling edge.
Is this the correct and easiest way to solve my problem?
Thank you very much :)
Scholar austin
Much Better,
Be careful, as clock domain crossing requiresa synchronizer to prevent metastability.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor oscarseijo
Thanks for the advice :). Now im having synchronization problems, but I think I can solve them by myself.
Thank you really :D
Óscar.
